Back to current style
FULL COMBO (Short)
Scaled-down version of the main NPS style. (All features are the same.)
If the main version is too tall to fit on your screen, this one should be a better fit.
"How do I know if I need this version?"
Look at how wide the album art is. It should be the same width as the info card below the art. If the art is much smaller than the info card, that means the info card is too tall for your screen. In that case, using this version will make your album art show larger.
Version notes
Fixed missing cases in Rating strings
  • Full player now correctly shows 2-star rating
  • Mini-Player now correctly hides 1-star rating while playing
Report this version
