Back to current style
FULL COMBO (Short)
Scaled-down version of the main NPS style. (All features are the same.)
If the main version is too tall to fit on your screen, this one should be a better fit. I've shrunken down a bunch of stuff and removed some margins to help it fit smaller screens.
The only changed feature is that the Cover artwork is set to "Visible" instead of "Fill Size".
  • Pro: The artwork will always have rounded corners, no matter how it fits on screen
  • Con: The Mini-Player Rating & buttons will appear over the artwork instead of in the gap.
Feel free to change it back to "Fill Size" if you want to match the normal version of this theme.
"How do I know if I need this version?"
Look at how wide the album art is. It should be the same width as the info card below the art. If the art is much smaller than the info card, that means the info card is too tall for your screen. In that case, using this version will make your album art show larger.
If the art is still too small...
...you'll have to manually adjust some sizes or disable strings you don't need. (First things to disable are probably the Ratings on String 2, Composer Info on String 6, or the Queue Info on the "Top Bar".)
Screenshots aren't 100% accurate
The big gap in the middle is usable space for the theme.
I only have one device to screenshot on and I don't need the extra space, so the screenshots look a little silly.
Version notes
Specific to short version:
  • Cover art is now fixed at the top instead of centered
Summary of main version's changes:
  • Compact Player overhaul
  • Album Artists and Performing Artists marquee separately
  • Album Artist now shows even if included in Performing Artists
  • "Various Artists" is now shown if no other info present, instead of always hiding it
  • Explicit indicator has been moved near the Lyrics button
  • Ratings bars now show tagged Rating (★ stars) when UserRating (● circles) is not set
  • Ratings for Mini Player & Landscape Cover can now be hidden by long-pressing them
  • Comments removed from all strings
...plus some other misc. bug fixes and adjustments.
v3.0.0 -> v3.0.2
  • Enabled "end ellipsis" for Landscape String 3
  • Removed broken stub from P/L String 1
Report this version
