FULL COMBO (Short)
Scaled-down version of the main NPS style. (All features are the same.)
If the main version is too tall to fit on your screen, this one should be a better fit. I've shrunken down a bunch of stuff and removed some margins to help it fit smaller screens.
The only layout changes are 1) that the Cover artwork is set to "Visible" instead of "Fill Size" and 2) String 3 is set to "At most 2" lines instead of "Always 2"
- Pro: The artwork will always have rounded corners, no matter how it fits on screen
- Con: The Mini-Player Rating & buttons will appear over the artwork instead of in the gap.
Feel free to change it back to "Fill Size" if you want to match the normal version of this theme.
"How do I know if I need this version?"
Look at how wide the album art is. It should be the same width as the info card below the art. If the art is much smaller than the info card, that means the info card is too tall for your screen. In that case, using this version will make your album art show larger.
If the art is still too small...
...you'll have to manually adjust some sizes or disable strings you don't need. (First things to disable are probably the Ratings on String 2, Composer Info on String 6, or the Queue Info on the "Top Bar".)
Screenshots aren't 100% accurate
The big gap in the middle is usable space for the theme.
I only have one device to screenshot on and I don't need the extra space, so the screenshots look a little silly.
Version notes
Removed erroneous movement.name condition from String P1's Chapter Index/Title separator
String 3 is now set to "At most 2 lines," shaving off a usually-blank line
