FULL COMBO
This aims to be the most feature-complete NPS theme available, including dynamic support for Classical music and Audiobooks. It also has a secondary “Mini-Player” view, which doubles as a dedicated Chapter player--displaying a secondary progress bar tied to the current chapter.
Tap the cover art to toggle the Mini-Player. (Portrait only)
Designed to show as much useful metadata as possible without cluttering the screen, the fields shown will change to fit the type of media you are playing.
- General Music: focuses on title/album/artists
- Classical Music: focuses work/movement/composer
- Audiobooks: focuses on chapter info
The Queue Info section intelligently displays all relevant features: chapters, repeat, shuffle, Smart Queue, Smart Flow, Sleep Timer, and end-of-queue.
A shorter version is available!
Check how wide the album art is. It should be the same width as the info card below the art. If the art is much smaller than the info card, that means the info card is too tall for your screen. In that case, using the the shorter version will leave a bit more room so your album art can be larger.
Recommended Fonts
The default Symfonium font makes some of the Unicode characters look funny (like the Rating circles). Many of the other built-in ones work fine, like "Lato" and "Inter". Personally I use "Murecho" (enter it in custom option).
Note on Images below:
Images 1-4: General Music layout
Images 5-8: Audiobook layout
Version notes
Audiobooks will display Publisher info (read from LABEL field)
REQUIRES APP v15+ to show Publisher info (will show Format info if Label is unavailable)
