Back to current customization
-Layer Finder-
Do you want to make your own color themes? Are you intimidated by the long list of slots and their scary names? Well it’s about to get a whole lot easier!
This color theme highlights each UI element in a distinct color. Importing this theme will let you visually ID which slot almost any UI element is taking its color from.
This is a tool. Don't expect it to look pretty.
I did my best to keep text as legible as possible, but there are a few spots that may be hard to see. Both Light & Dark theme are set to the same colors, but some elements may still be changed by your device.
Usage
Make sure to DISABLE the “Now playing color source” option since it will override many of this theme’s colors.
Navigate to the UI element you want to change, note what color it is, then go back to Theme settings and tap on “Selected theme colors”. You should be able to easily find which slot’s color is being used. If you want more confirmation...
Notice:
This theme does NOT use white #FFFFFF or black #000000. Anything you see in those colors likely cannot be changed by Symfonium. (Check your device settings for Day/Night mode, Theme colors, etc.)
So to confirm that you’ve got the right slot: edit this theme, change the likely culprit to WHITE or BLACK and then navigate back to the UI element to see if it changed. (You can import this theme again to "reset" its colors.)
Now that you know what slot you want to change, you can swap back to your real theme and set the color you want!
Link to Symfonium's official docs:
https://support.symfonium.app/t/theme-colors-documentation/3950
Version notes
The colors for "outline" and "surfaceContainerHighest" have been updated to make it more clear that ON/OFF toggles do not share color slots.
Report this version
