Back to current customization
Power -S-
I'm hoppin' on the Clone Train, bringing y'all a fresh design--based on a certain other power player. Get amped!
Layered Progress bar
Thanks to a few tricks, v16 allows me to place buttons on top of the Progress Bar.
The bar itself is pretty tall, so you can still comfortably slide-to-seek. (Touch a little bit above or below the buttons.)
If you want to adjust the position of these buttons, it is controlled by: "Bottom bar -> Padding -> Vertical content offset"
Special Features
This theme is pretty light, but I still snuck a little Symfonium-goodness in there!
In Portrait, you can tap the Cover art to hide the Title & Artist text. Enjoy a clean view of the artwork!
Other actions
  • Long press the Cover for the "More Actions" menu
  • Tap the audio format info (the bottom text) to see the upcoming track
  • Tap the Queue info (little numbers at the middle) to open the queue screen. Long press to change queues.
  • Long-press the Progress Bar timers to pick a position to seek to.
  • Swiping up opens the Lyrics screen. (Or use the button.)
Disclaimer
Right now, this style doesn't play well with "Floating" navigation bars. I'll see if I can do anything about it, but for now you'll want to use any of the other nav. styles.
Report this version
