AMO-RED
Minimal design - For using the Home Page as a landing screen. There are quick shortcuts but most browsing should be done in the Library tab.
Intended as a 2-3 page layout - I left some gaps to hide the camera cutout... You may need to adjust the spacing a bit to suit your phone. Fortunately, the app makes that easy to do!
Newly-added music will pop in at the top if you add some new music. I recommend replacing these with Smart Playlists for better control.
Suggested Music - Space to link your Smart Playlists to help you pick something to listen to. This will be empty until you set your own playlists here. Example setup shown in last screenshot.
See here for more details on the NPS style.
Version notes
- Updated color style
- Misc bug fixes
