AMO-RED
Minimal design - For using the Home Page as a landing screen. There are quick shortcuts but most browsing should be done in the Library tab.
Intended as a 2-3 page layout - I left some gaps to hide the camera cutout... You may need to adjust the spacing a bit to suit your phone. Fortunately, the app makes that easy to do!
Smart Playlists
Be sure to download these as well! Import the four playlists to enable two sections:
Recently Added music pops in at the top if you add something new. And it will go away once you've listened to it!
Suggested Listening helps you pick something that you haven't heard in a while.
NPS Details
See here for more details on the NPS style.
There is also a shorter version of the NPS. (If the album art is very small on your screen, you probably should use this Short version.)
Current version notes
As always, many NPS bug fixes and adjustments. See my FULL COMBO page for more details.
3.2.2 -> 3.2.3: Fixed "Covered by" header showing even if Album Artist is hidden
Associated color themes
Simply RED
A simple, red color palette
Version 1.1.0
Associated now playing styles
Associated smart playlists
Previous versions
3.0.2 (2026-08-03)
Re-pinned Smart Playlists, as per app v15 guidelines Replaced default Recently Added rows with my Smart Playlist versions Smart Playlists are linked below for easier importing…
