AMO-RED
Minimal design - For using the Home Page as a landing screen. There are quick shortcuts but most browsing should be done in the Library tab.
Intended as a 2-3 page layout - I left some gaps to hide the camera cutout... You may need to adjust the spacing a bit to suit your phone. Fortunately, the app makes that easy to do!
Features
Newly-added music will pop in at the top if you add some new music. I recommend replacing these with Smart Playlists for better control.
Suggested Music - Space to link your Smart Playlists to help you pick something to listen to. This will be empty until you set your own playlists here.
NPS Details
See here for more details on the NPS style.
Check the linked styles below for the shorter version. (If the album art is very small on your screen, you probably should use the Short version below.)
Version notes
NPS adjustments/bug fixes only:
Fixed missing cases in Rating strings
- Full player now correctly shows 2-star rating
- Mini-Player now correctly hides 1-star rating while playing
