Back to current style
AMO-RED
Minimal design - For using the Home Page as a landing screen. There are quick shortcuts but most browsing should be done in the Library tab.
Intended as a 2-3 page layout - I left some gaps to hide the camera cutout... You may need to adjust the spacing a bit to suit your phone. Fortunately, the app makes that easy to do!
Smart Playlists
Be sure to download these as well! Import the four playlists to enable two sections:
Recently Added music pops in at the top if you add something new. And it will go away once you've listened to it!
Suggested Listening helps you pick something that you haven't heard in a while.
NPS Details
See here for more details on the NPS style.
There is also a shorter version of the NPS. (If the album art is very small on your screen, you probably should use this Short version.)
Version notes
Second NPS hotfix. Place your bets on what else I missed this time...
Report this version
