Shifting Hues
A card-based Home layout. The dynamic counterpart to my AMO-RED style.
Don't let the subtle colors fool you... Once a queue is open, say "Goodbye!" to your theme colors!
This theme only uses the theme palette when there is no queue open. When you start playing media, almost everything gets swapped out for Artwork-based colors.
Want to keep solid black backgrounds?
Enable the "Ignore background and surfaces" toggle.
Dynamic Artist page layout
Some adjustment may be needed on your end!
This setup won't work for everyone out-the-box. Portrait should generally be fine, but Landscape is very dependent on screen space.
If you can't see the buttons next to the Circle artist image (or if they're squished really small), please do either of the following:
  • Increase the "Header pane width"
  • Decrease the "Image size" slider (found in Artist page -> Landscape header -> Appearance and artwork)
The page preview isn't reliable for this (since the navigation bar eats up some space, but isn't shown) so you'll have to do a bit of trial-and-error to get the sizes right.
If you have a 16:9 screen, try the following sizes:
  • Header width: 50%
  • Image size: 230
If you have a 20.5:9 screen? Congrats, so do I! You won't need to adjust anything. :)
If you don't want to fuss with it (or don't use fanarts):
Simply set the "Image size" slider to zero and change the "Header Background" to "Image". This will give you the big-picture style for all your artists.
NPS style: CleanDeets
This style is intentionally very light. It has a simple CD-style artwork with a small Glass information panel. You can long-press the timers on the Compact Player to quickly seek to a position.
If you're looking for something more advanced, please check out my FULL COMBO and 16x COMBO NPS styles.
Compact Player DISABLED in landscape
In landscape orientation, the "Search" tab is replaced with the "Now Playing" tab.
Before, we had to choose between:
  • the convenience of the Compact Player
or
  • more screen-space for landscape...
Now you can enjoy the best of both worlds!
Current version notes
Initial release
Full parity with AMO-RED v4.0.0 App Style
